Activity Forums Maxon Cinema 4D Extruding and Beveling
  • Extruding and Beveling
    Posted by Mike Diluigi on October 10, 2016 at 5:36 pm
    I am trying to extrude then bevel a fairly simple shape, but am running into some trouble with the geometry when I try to bevel the edges. The straight edges and corners seem to be okay, but the curved sections don’t appear to be smoothing out like I thought they would when I render, resulting is a striped looking pattern around the curved sections. I tried beveling with the modeling tool and the bevel deformer, but I got similar results with both. I figured it was a problem with the phong tag, but adjusting the phong tag properties did not help.
    You can view the scene file here:
    https://www.dropbox.com/s/vl2aqyjpqc2elah/bevel_test.c4d?dl=0
    Thank you!
    Mike Diluigi replied 9 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 10, 2016 at 9:40 pm
    The funky geometry of the bevels is messing up the phong shading, as you deduced. You can improve the result by selecting the edge loops on either side of the bevel and runng the “break phong shading” command.
    Here: 10674_beveltestbreakphong.c4d.zip
  • Mike Diluigi
    October 11, 2016 at 3:49 am
    That was it! Man, still SOOO much to learn about modeling.
    Thank you very much for your help, Adam! You have temporarily delayed my inevitable insanity.
