Activity › Forums › Boris FX › Extruded EPS shifting Z-depth
  • Extruded EPS shifting Z-depth
    Posted by Naveen Mallikarjuna on March 15, 2010 at 5:38 pm
    I’m new to this filter, so I apologize for the newb question.
    I have an EPS that I’m bringing into After Effects. Call this Layer 1. I then put a solid over top of it. Call this Layer 2. I then apply BCC Extrude EPS to Layer 2. I reference the same EPS file as Layer 1.
    What I would expect is for Layer 2 to be an extruded version of Layer 1, perfectly aligned.
    However, Layer 2 is moved forward in Z-space. (Viewed at an angle, the extruded EPS is hovering above Layer 1).
    Strangely, if I preview at Half resolution, it is not shifted in Z space. Layer 2 is directly locked Layer 1, and stays locked to it even as I move the camera.
    Does anyone have an idea of how to get rid of this z-space shift. Why does it move the layer?
    Naveen Mallikarjuna replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
