Activity Forums Boris FX Extruded EPS in After Effects is changing fonts
  • Extruded EPS in After Effects is changing fonts
    Posted by Zach Rutledge on March 10, 2010 at 7:02 pm
    When I try to extrude an EPS file BCC is changing part of the logo font and I am actually losing characters in the logo. Any ideas?
    Boris Yamnitsky replied 16 years, 5 months ago 2 Members · 1 Reply
  • Boris Yamnitsky
    March 14, 2010 at 2:37 pm
    Zac,
    To lock in a font try to convert your EPS to outlines in Illustrator (if if you have Illustrator and willing to do that). Also, make sure that the desired font is installed on your system and works in AE itself. What kind of font is it?
    If you are seeing letters dropping out, I suspect the type may be too small for extrusion. Again, in Illustrator, if possible, increase the font size or make it bold. Some curves are hard to extrude if they are too tight or tiny.
    Let me know if this helps,
    Boris Yamnitsky
    BorisFX
