Activity Forums Maxon Cinema 4D Extruded dots on a sphere
  • Extruded dots on a sphere
    Posted by Bob Perkerwicz on March 5, 2010 at 1:48 am
    I am trying to make a sphere shape with latitude and longitude lines on it. And at the center of each square created by the lines, an extruded circle. The lines would be separate and the extruded circles would be separate. In one case I would need 50 extruded circles, and in another case 600. Inside the spherical shapes, I need to put a model inside the sphere with the lines and circles in a spherical shape around the model. Any help would be appreciated. Thanks!
    Bob Perkerwicz replied 16 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 6, 2010 at 5:39 pm
    One way to create the extruded circles would be to clone cylinders onto your sphere with MoGraph. Then you could scale them smaller towards the poles using a step effector.
    If you don’t have mograph….
    Since the sphere polygons get smaller and more rectangular at the poles, the circles in the following method actually become ovals towards the top:
    * make your sphere editable;
    * select all the polygons;
    * run functions>disconnect with group unchecked;
    * place your sphere in hypernurbs object;
    * set the HN object to two subdivisions (editor and render);
    * make the HN editable;
    * select all polygons and extrude to your preferred depth.
    For the lat/long lines, you can either place the sphere in the Atom Array object (set ball size to same width as pipe size), or you can do the following:
    * make sphere editable;
    * select all polys;
    * run the extrude inner command, with groups unchecked;
    * immediately after, the inner polygons should be selected — hit the delete key to delete them, leaving just the lat/long polys.
  • Bob Perkerwicz
    March 6, 2010 at 6:13 pm
    Thanks Adam!
