Activity Forums Maxon Cinema 4D Extruded arrow along a path
  • Extruded arrow along a path
    Posted by Carlos Angulo on June 28, 2007 at 1:20 pm
    I need to know which is the best way to make an extruded object, lets say an arrow for example, to deform along a path, I tried it using a extrude nurbs and then applying a Spline rail deformation but I didnt get any results.
    Can anybody help me out with this?
    Adam Trachtenberg replied 19 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 28, 2007 at 4:55 pm
    You’ll either need the MoGraph module or a plugin to do this effectively. With MoGraph you would use the spline wrap deformer. Plugins that can do it — off the top of my head — are Multiple Splie Attach (MSA) and Path deformer (https://www.tarabella.it/c4dbeta/index.php)
