Activity Forums Maxon Cinema 4D Extrude Text with holes…using boolean??
  • Brian Jones
    January 19, 2011 at 12:02 am
    – connect the three parts of the R then Optimize
    – take the star extrude out of the two nulls it’s in (toss the nulls)
    – move the extrude forward a bit (-Z) because it’s inside or at the exact same level as the face and it can’t cut the face
    – probably turn off High Quality in the Boole cause I think that’s what you are expecting the star to do (it can be done differently but that will work)
