Activity Forums Boris FX extrude spline
  • extrude spline
    Posted by Eyad Abutaha on September 20, 2009 at 10:27 pm
    Hi guys;
    I’m using bcc extrude spline for a logo I have; the problem am having is the plug-in allow me to use only one mask as path type; I have to use 2 masks to draw the logo; is there a fix for that. The logo will look totally different if I use only one mask.
    Peter Mcauley replied 17 years ago 2 Members · 3 Replies
  • Peter Mcauley
    September 20, 2009 at 10:51 pm
    There is a workaround but it involves using Adobe Illustrator to merge the paths and the BCC Extrude EPS filter instead of the BCC Extrudes Spline filter. Here’s how to do it:
    • copy the mask paths from After Effects into separate layers in Illustrator – copy/paste should work
    • fill the objects with color
    • save the file from Illustrator as Illustrator EPS version 8
    • in After Effects, replace the BCC Extrude Spline filter with the BCC Extrude EPS filter
    • import the saved Illustrator file into the BCC Extrude EPS filter
    We have discussed the use of multiple spline masks in AE and I suspect this will become available in a future release of the product but for the time being, the BCC Extrude Spline filter can only extrude one mask path shape.
    I hope this helps,
    Peter.
  • Eyad Abutaha
    September 21, 2009 at 12:20 am
    Thanks Peter for the quick respond; i will follow your directions later since am away from my computer now; but as i recall i dont think i have a filter called BCC Extrude EPS; any ways i will check later on today.
    Thanks anyways
  • Peter Mcauley
    September 21, 2009 at 5:52 pm
    Hi Eyad,
    If you have the current version of BCC 6 then you will have the BCC Extrude EPS filter.
    Cheers,
    Peter.
