Activity Forums Maxon Cinema 4D Extrude Spline, texture
  • Extrude Spline, texture
    Posted by Kurt on February 4, 2006 at 9:23 pm
    I have drawn a spline in C4, added extrude nurbs for a slight depth. When applying a texture, however, the texture only shows up on the edge that was extruded, not on the cap. How do I fix this?
    Inother words, how do I get the texture to be consistant on all sides of the model.
    Kurt replied 20 years, 7 months ago 2 Members · 2 Replies
  • Doug Bassett
    February 4, 2006 at 10:11 pm
    Set the projection to flat. You may need to turn off tiling.
  • Kurt
    February 5, 2006 at 10:18 am
    hmm, did not work
