Activity Forums Maxon Cinema 4D Extrude problem
  • Extrude problem
    Posted by Chad Demoss on July 7, 2015 at 10:42 pm
    I drew a spline, lofted it, then tried to put it in the extrude nurb and nothing happens. I threw a reqtangle shape in the extrude and that works. i drew a simple circle an that works. i put the loft in a connect but that didn’t do anything. I think I’m missing a step.
    Brian Jones replied 11 years, 1 month ago 2 Members · 2 Replies
  • Chad Demoss
    July 8, 2015 at 4:16 pm
    never mind this simpler object worked, there was a more complex object I brought in from illustrator that did not work and I’m not exactly sure why.
  • Brian Jones
    July 8, 2015 at 5:00 pm
    doing a loft of a spline and then extruding (I assume for thickness?) won’t work, as the extrude takes splines as input and if the directions of the spline and in the extrude are set correctly the extrude gives you thickness.
