Activity › Forums › Maxon Cinema 4D › extrude nurbs caps converted to polys
  • extrude nurbs caps converted to polys
    Posted by Jonas Espinoza on February 7, 2007 at 12:50 am
    is it possible to convert an extrude nurb to a 4 side self contained poly.
    right now i grab the face and it comes right off instead of stretching the sides and staying still intact.
    also- am not sure the command, have played around quite a bit, if i have a few poly’s that are faces of what i think of as an object, what is the way to make them all connected faces of one poly? i have used connect but it seems to leave some faces disconnected
    thanks for all the help
    Mylenium replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mylenium
    February 7, 2007 at 6:20 am
    Connect will not merge the vertices, it will only combine separate strips of polygons into a single mesh entity. You have to use Function –> Optimize or use the Merge tool.
    Mylenium
    [Pour Myl
