Extrude Nurbs and joint tool
I’m trying to create a box that opens up to be flat and then folds back up.
When I try to use the joints, I’m getting some unwanted results.. this may be a modelling problem rather than a joints problem.
Here are the steps I’ve done so far:-drew a spline representing one side of the box (it’s kind of a weird shape)
-dropped spline into extrude nurbs (no fillets)
-changed extrude nurbs into polygon
-connected all resulting polygons together
-added joints to the new object
-rotate joints and you get this result (see attached).How do I model this thing so that I just get flat surfaces even when folded and manipulated?
Here’s the project:
3694_boxfold01.zip
The uncommitted extrude nurbs is in the “backup” null.
