Activity Forums Maxon Cinema 4D Extrude creates a block, ignoring the empty areas within a spline
  • Extrude creates a block, ignoring the empty areas within a spline
    Posted by Joey Heaton on August 9, 2018 at 6:34 pm
    Hello and apologies first off because this is probably a very newbish question (I only recently started learning Cinema 4D in fact).
    I created a path in Photoshop, exported the paths to an .ai file, and merged it into a Cinema 4D project, then used Extrude on the splines, but it hasn’t turned out the way I wanted.
    As you can see, Extrude has created a completely filled in block, whereas the splines have an empty section in between. I’m sure it’s an easy fix but I honestly didn’t even know how to word a Google search for this, so my question is, why is it doing this (i.e. what am I doing wrong), and how do I get the result I desire?
    Thank you in advance!
    Joey Heaton replied 8 years ago 3 Members · 6 Replies
  • Michael Szalapski
    August 9, 2018 at 7:29 pm
    How did you merge them in Illustrator? Wait, are you sure both splines are closed?
    Regardless, you can split them apart in C4D and then use a Spline Mask to make it do what you want or just run the Connect and Delete command. Either way, my test splines are behaving the way you want, so I don’t know what’s up.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Joey Heaton
    August 9, 2018 at 8:19 pm
    I decided to start from scratch and trace them in Illustrator… but when they get imported into Cinema 4D, the spines aren’t closed… I don’t understand why.
    Illustrator:
    Cinema 4D:
  • Emir Bojorquez
    August 9, 2018 at 9:28 pm
    cleck and check the “Close Spline ” option in every spline to se if that helps.
    Good luck
    Imagination is the best tool…
  • Joey Heaton
    August 9, 2018 at 9:30 pm
    If I check “Close Spine” it just turns it into a block again…
  • Emir Bojorquez
    August 9, 2018 at 11:13 pm
    If you could share your file, we can take a look
  • Joey Heaton
    August 10, 2018 at 12:55 pm
    I decided to just retrace it with the pen tool in Cinema 4D itself, rather than wasting time with import issues. It works the way I intended it to now.
    Thanks for your help though. 🙂
