Activity Forums Maxon Cinema 4D Extrude around a bend
  • Extrude around a bend
    Posted by Darryn Rogers on February 12, 2020 at 4:43 am
    I’m doing some basic modelling and want to extrude a face a number of times, rotating around an offset axis so that I end up with a curved extrusion (See B in the pic).
    I’ve figured out how to do this by selecting the face, offsetting the axis, then control/shift rotating to duplicate the face in 5 degree increments. This works but it’s damned laborious.
    Matrix extrude is frustratingly close to what I need but it doesn’t allow for the offset of the axis. Is there a script or a plugin to do this or some inbuilt tool that I am missing?
    Sam Treadway replied 6 years, 7 months ago 2 Members · 1 Reply
  • Sam Treadway
    February 13, 2020 at 4:08 am
    Try MoExtrude instead:
    Make it a child of the polygon object and link to the polygon selection tag and a spline profile (arc spline for instance).
    This method is also non-destructive and can be animated by manipulating the spline objects points with deformers on the spline, etc.
