Activity › Forums › Apple Final Cut Pro Legacy › Extrude alpha channel?
Posted by Michael Peele on July 14, 2005 at 8:39 pmIs there any way to extrude alpha channels in FCP? Are there plugins to accomplish this?
Thanks for the help,
MikeMichael Peele replied 21 years, 2 months ago 3 Members · 3 Replies -
David Bogie
July 14, 2005 at 10:31 pm“Extrude?”
Run that by me again. What would you do with an extruded alpha?
bogiesan
Andy Mees
July 15, 2005 at 1:23 pmFCP doesn’t operate in a defined 3D space, and I’m not aware of a third party plugin to handle something like extrusion (although i may be wrong). you might want to look at After Effects?
cheers
Andy -
Michael Peele
July 16, 2005 at 1:19 amWell, my line of thinking on extruding an alpha channel was contingent on a pretty well defined alpha channel – you know standard logo on a transparent background. I know that in Boris, if you have an illustrator .eps, you can extrude the edges to create a simple 3d shape, which can then be tumbled/rotated/etc.
Well unfortunately, customers usually don’t have their logos done in illustrator, or at least they don’t have a copy of the illustrator logo. Often enough I am cleaning up a scanned letterhead, grabbing from the internet, or some other mickey-mouse way of getting the logo into photoshop. But even then I end up with no paths or vector artwork, just pixels.
So here I am, trying to just get some depth based on a clean alpha edge, and I think Andy Mees may be right – AE is the only way to do it. Boris wants an .eps, FCP has no built in solution, and I have seen no plug-in that seems to help.
Thanks for the replys,
Mike
