Activity › Forums › Maxon Cinema 4D › Extrude 2d Image With Alpha Channel? {Cinema4d}
  • Bill Bronner
    August 13, 2010 at 2:08 pm
    If it’s a photoshop file you can make a selection based on that alpha. Then save the selection as a work path, and export it as a an illustrator path. You can then simply drag and drop the file into you C4D viewport and throw an extrude nurb in the mix.
