Activity Forums Apple Final Cut Pro Legacy Extremely slow rendering times
  • Extremely slow rendering times
    Posted by Mykal Williams on April 1, 2015 at 9:27 pm
    Hey so I should probably preface this by saying I’m pretty new to this so any technical terms or specs will probably have to be explained to me. For some reason, I started getting extremely slow rendering times even when rendering the most simple of changes. Things are taking way longer than they should and it wasn’t always like this. I’m not sure how to fix this problem.
    Please help as soon as you can.
    Thanks 🙂
    Mykal Williams replied 11 years, 5 months ago 3 Members · 6 Replies
  • Jerry Wise
    April 1, 2015 at 10:37 pm
    maybe you are using very large pics or graphics. are you using footage that is h264.? in sequence settings/video processing make sure that you have “always render in rgb” ticked.
  • Mykal Williams
    April 2, 2015 at 1:14 am
    Yeah I tried that. It didn’t work
  • Shane Ross
    April 2, 2015 at 3:41 am
    What is the codec of the footage you are working with? What camera are they from? Did you convert it before you brought it into FCP? What did you convert it to? What are your sequence settings?
    Shane
    Little Frog Post
  • Mykal Williams
    April 2, 2015 at 9:05 pm
    Here are my sequence settings:
    The video is literally just a jpeg with music and the “Bad TV” filter. This isn’t the only project this has happened in though. I didn’t covert anything.
  • Shane Ross
    April 2, 2015 at 9:58 pm
    So just a still picture and the BadTV filter? No Quicktime footage or camera footage?
    Well, the BadTV filter is pretty render heavy…because it has to basically create all that noise and distortion. That takes time.
    Shane
    Little Frog Post
  • Mykal Williams
    April 2, 2015 at 10:47 pm
    Yeah but I’ve used just regular jpegs before and it probably would have taken an hour to render.
