Activity Forums Apple Final Cut Pro Legacy Extremely poor performance
  • Extremely poor performance
    Posted by Mike on November 2, 2006 at 2:28 pm
    OSX 10.4.8, Dual 2.7 G5, 1 GB SDRAM
    Running Final Cut 5, and I can hardly do anything without
    getting the dropped frame errors. Just one video channel
    playing back, and it still has trouble. I’ve had this problem
    with this machine since I’ve got it. Just a few weeks ago, I
    wiped the drive clean and reinstalled everything, and still
    the same problems.
    I have a 3 year old Dual 1 GB G4 that runs FCP 5 flawlessly.
    I’ve also notice even Quicktime having trouble
    playing back without stuttering.
    Any ideas?
    Don Greening replied 19 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    November 2, 2006 at 3:04 pm
    What drive’s in the computer? What’s the media?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Mike
    November 2, 2006 at 3:16 pm
    Most often, I’m just using the internal, which, I’m
    aware that’s not how you’re supposed to do it. But,
    I have no troulbe with other machines. In fact, I did
    most of my work on my old G4 for 3 years with no
    trouble. I’m just working in a DV timeline.
    I might have just found something. The energy saver
    on G5’s now have a drop menu for proccessor
    performance, which was set to auto. I found
    a tech doc that said it should be set to ‘Highest’
    for those doing intense work.
    That would make sense if that’s it, because quicktime
    and other apps would also lag or freeze on me.
    I’ll keep you posted if that’s it.
  • Andrew Commiskey
    November 2, 2006 at 6:05 pm
    Some weird things that happened with the same set-up (dual 1gig G4)
    in playback make sure the timeline is selected if the browser or effect parameters are selected playback was jerky. I cannot figure out why, You can deselect the drop frame warning which alows it to play throughthe dropped frames. also, because FCP 5 offloads alot on the GPU (videocard) an upgrade is very helpful.
    http://www.macsales.com has options.
    Good Luck
    Drew
    Chaos is the beginning of everything.
  • Zak Mussig
    November 2, 2006 at 6:55 pm
    C-dub,
    I don’t believe FCP made use of the GPU until 5.1.2, and even then only to accelerate FX-Plug effects. I think we all expect a lot more in terms of GPU acceleration in FCP for version 6, but for now I don’t believe it makes much use of your graphical horsepower.
    Zak
  • Don Greening
    November 3, 2006 at 12:09 am
    Mike, could you post a link to that tech doc? I’d be interested in what it has to say. TIA
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Mike
    November 3, 2006 at 12:53 pm
    I created a new thread with the link.
    By the way, It didn’t fix my problem, but it can’t hurt either.
  • Don Greening
    November 3, 2006 at 7:58 pm
    Okay thanks Mike. I already changed my setting to highest but haven’t noticed any change in performance. I’ll go to those links you posted up above.
    – Don
