Activity Forums AJA Video Systems EXTREMELY long saves after capture
  • EXTREMELY long saves after capture
    Posted by Shawn michael Lee on July 21, 2006 at 8:20 pm
    I am just expecting too much? I just began using my new XENA LS card this week. A problem I am having is this:
    If I capture a long piece of footage (anywhere from 20 minutes to 1hr 20min) such as a guest speaker at a lecture, I press stop and Premiere opens the box to “Save Captured Clip”. I then enter the name of the clip and click OK. After that, the drive runs for 15 minutes minimum (no exaggeration) to save the file. I know the file is big. But isn’t this card supposed to capture and write to disk in real time?
    I’m coming from an AVID Adrenaline to this system. On the AVID I record, stop and that’s it. I’m free to edit right away. Why not here?
    Lowrysam
    Paradisiak replied 20 years, 1 month ago 4 Members · 6 Replies
  • Rededitor
    July 22, 2006 at 7:11 am
    I had the same problem initially… I think you may be saving the file twice… check your Raid disk after you’ve done the save… is there a second file there (Untitled or such) of the same size? If there is, that’s why it’s taking so long, because you are actually re-saving as another file…. check your capture settings.
    Cheers
    RED
  • Paradisiak
    July 24, 2006 at 3:29 pm
    I have the same probleme, the save are extremely long when I capture clips manually but don’t happen when I batch capture.
    My other problem is I have a lots of duplicated files but the weird thing is they have the same name but not the contents, here is an example;
    I capture a clip named test.avi/test.wav and when I look in mydrive I also see an clip named test 01.avi/test 01.wav but it doesn’t have the same size and either the same content.
    I’ve checked my capture setting and doesn’t find anything related to re-saving file after capturing.
    Need help or advice because i’m wasting a lots of space and energy trying to manage my files…THANKS.
  • Tim Kolb
    July 25, 2006 at 1:57 am
    [PaRaDiSiaK] “capture a clip named test.avi/test.wav and when I look in mydrive I also see an clip named test 01.avi/test 01.wav but it doesn’t have the same size and either the same content.”
    This sounds like scene detection behavior…
    Perhaps there was a camera stop/start in the section of tape you captured and the program broke it there and created two clips?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Paradisiak
    July 25, 2006 at 3:47 pm
    Thanks Tim for your quick response, but I already check for the scene detection feature and that not the probleme.
    The thing that I found is that I must named my clip before I start the capture process, this way when I stop capturing it save the clip right away and don’t duplicate the name, but if I rename the file… the duplication start again. By the way the duplicated file is made of a file already captured… that’s weird and annoying. I’ll keep troobleshooting this issue and keep you informed.
    If anyone have a solution for this, don’t hesitated… you’ll make my day.
    Thanks to all.
    PRDSK
    Olivier Paradis aka PaRaDiSiaK
    https://www.jetfilms.com/
  • Shawn michael Lee
    July 25, 2006 at 7:37 pm
    I’ve had the exact same results that you have. I get a duplicate file if I rename it at the “Save File as” window. AJA theorizes that the first file is the raw capture (video only) and a seperate audio file. (Example: unknown 1.avi and unknown 1.wav). The second file that is created is the video with the audio interleaved and the new name (thus making only one file. Example: JonesInterview.avi). Then the original files SHOULD BE deleted. I haven’t tried it yet. If you do capture again, let us know if this is the case.
    Also, AJA suggests a 3 drive RAID minimum (SCSI). I have a 2 drive SATA RAID.
    Thanks.
    Lowrysam
  • Paradisiak
    July 26, 2006 at 8:32 pm
    The solution is to name your clip before you start the capture process, this way you don’t wait for the EXTREMELY long saves and don’t get duplicated files. Let me know if this solve your issue.
