Activity Forums Blackmagic Design extreme/dvcpro deck set to DV
  • extreme/dvcpro deck set to DV
    Posted by Michelle De long on November 29, 2005 at 7:43 pm
    System is
    FCPHD 4.5
    Blackmagic Extreme Decklink card
    We have set up our Decklink Extreme card with a DVCPRO deck. We set the DVCPRO deck to DV playback (using mini-dv tapes) and SDI out to the extreme card.
    We are not seeing any input video on the Blackmagic NTSC 10-bit, 8 bit or any other setting.
    What setup do we use?
    Thanks a bunch.
    Geir Ove thorsveen replied 20 years, 9 months ago 2 Members · 1 Reply
  • Geir Ove thorsveen
    November 30, 2005 at 9:35 am
    Should work just fine with either the Blackmagic 8-bit or 10-bit easy set-ups. The SDI card on the DVCPro deck converts the DV video to 8-bit 4:2:2, so it should work just like any other SDI source. Are your input settings under “Apple menu”->”System settings” (or something like that, non-english OS here)-> “BMD Decklink” set to SDI?
    Cheers,
    Geir.
