Activity Forums Adobe Illustrator extreme warping
  • extreme warping
    Posted by Christopher Glavan on July 7, 2010 at 5:13 am
    Disclaimer: I’m fairly new to Illustrator.
    Using CS4, I’m trying to create a film strip unwound from a reel that bends to form the letter ‘R’ as seen here: https://www.reelimpressionsmedia.com
    I have my reel and strip the way I want them, but I cannot figure out how to warp the strip and have the notches and frames follow the relative path! I’ve excluded the frames and notches (I can see the transparency grid in those areas) but I’m lost on the warp.
    Can someone walk me through the process, or at least point a newbie toward the right tutorial?
    Vincent Rosati replied 16 years, 2 months ago 3 Members · 2 Replies
  • Les Nemeth
    July 7, 2010 at 4:34 pm
  • Vincent Rosati
    July 7, 2010 at 9:24 pm
    I took a shot at your challenge also.
    I was able to create the leg of the ‘R’ by skewing a film frame, making a tile out of it, then creating a pattern brush and applying it to the path. It looks good, but…
    I couldn’t get anything to work well for the hard curves.
    I’d just:
    Draw the length of the film as a path, and set the weight.
    Duplicate the path to create the back edge.
    Draw the cells and the notch things by duplicating objects that you may already have.
    Then tweak the parts, by hand, that are in the tough spots. Boom. Done in 20 minutes.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
