Activity Forums Blackmagic Design Extreme PCIe – Dualcore Setup not getting it’s full power!
  • Extreme PCIe – Dualcore Setup not getting it’s full power!
    Posted by Bernie on December 1, 2005 at 1:01 pm
    Hi. I just bought a DL Extreme PCIe .
    I Have exactly the dual core setup that Blackmagic recomend:
    INTEL PENTIUM DUAL CORE
    Asus P5WD2 Premium
    Stewart Mayer replied 20 years, 9 months ago 4 Members · 4 Replies
  • Luke Maslen
    December 2, 2005 at 5:47 am
    Please try temporarily uninstalling the DeckLink drivers and removing the card. Now restart the PC and see if Windows can see all 4 GB of RAM. Also try some renders in Premiere Pro and see if there is any difference in performance. When you have completed your testing, reinsert the DeckLink card and then reinstall the latest DeckLink drivers.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Martin Kay
    December 2, 2005 at 10:10 am
    In my experience the 32bit version of Windows XP Pro will not use more than 3GB (from 4GB of RAM modules) no matter whether you have a PCI-Ex Decklink card installed or not. The motherboard supports it because different operating systems (eg Linux) support >3GB, but you will probably have to wait for Decklink drivers that run under the 64bit version of WinXP Pro before all your 4GB of RAM gets used.
    As for the Premiere Pro rendering only using 55% of CPU resources, I think some effects are only single-threaded so can only use one core.
    Regards,
    Martin
    ZEN Computer Services
  • Bernie
    December 2, 2005 at 10:54 am
    thanks guys.
    well, luke, i have been seen this problem (3GB limit) before the installation of the card…I guess it’s a Windows Xp issue…
    But what about the premiere processing getting only 55% of it’s power. it’s really annoing. I’m using only PPro built-in effects like color correction etc…(when PPro are booting there’s a text telling me that PPro sees Multiprocessor)
    **(is this color correction effect realtime if the DL card?)
    cheers
    and thank you guys for the replies.
    Bernardo
  • Stewart Mayer
    December 2, 2005 at 4:39 pm
    I’m pretty sure it is a premier pro issue, i’ve got two xeon nocona processors in my system with hyperthreading so It looks like 4 processors, and even when rendering heavy effects in premiere I rarely get above 25% cpu load. I’m not sure if it is because of multithreading, multiple processors, or perhaps the windows CPU monitor doesn’t calculate load correctly, but this is normal. I have no idea if it is a true measure of performance or not.
