Activity › Forums › Adobe After Effects › Extreme Grainy Edges
Posted by Lex Villena on August 20, 2018 at 8:15 amHow can I achieve an effect like the one see here on shapes? Messing with roughen edges comes close, but not exactly what I’m looking for as it’s not fuzzy enough on the edges.
Kalleheikki Kannisto replied 8 years ago 5 Members · 11 Replies -
Lex Villena
August 20, 2018 at 8:39 amPhotocopy comes close, but it’s the inverse of the above sample image…
Thomas Hannen
August 20, 2018 at 9:26 amThis looks to me like it was made in a 3D package like C4D or Blender, using Ambient Occlusion with the sample rate set very low to achieve the fuzzy effect.
Steve Bentley
August 20, 2018 at 6:17 pmYou might be able to get there with CC Ball Action. Precomp your shaded spheres and the apply the effect on the precomp in the outer layer. In the effect, animate the scatter attribute and set the ball size to something like 10. I’m not sure if the scatter effect should be a random number on each frame or a smoothly changing amount.
Steve Bentley
August 20, 2018 at 6:25 pmTwo other tips – try animating the instability state in the effect rather than scatter (yes, I got to playing; you will still need a scatter amount but it can be fixed).
You can also use the rotation and twist but you might have to rotate your precomped sphere by the same amount so the balls in the effect don’t go “round the clock”. Well, they will, but with the sphere rotating by the same amount, and probably the precom itself too, they should look like they are staying put meanwhile you have all this random motion going on with the balls themselves. -
Steve Bentley
August 20, 2018 at 6:26 pmAnd while it should be obvious, the spheres in the precomp will need a glow or gaussian blur on them to get that soft edge.
Lex Villena
August 20, 2018 at 8:49 pmI got fairly close using roughen edges and bevel, emboss. Not exactly, but close enough. Now I only have to figure out how to have them interact and bounce into each other like in the sample.
Lex Villena
August 20, 2018 at 8:51 pmNot nearly as noisey in the center as I’d like, though, even with dancing dissolve added to the shape layer.
Lex Villena
August 20, 2018 at 8:52 pmI’ll give the methods cited by you guys to see if it’s closer to the effect. Thank you.
Michael Szalapski
August 22, 2018 at 3:09 pmCC Ball Action or Trapcode Form would be capable of doing this if you really messed with it. (You’d need to work to remove the individual shading from the balls in CC Ball Action (unless you like that sort of thing.)
Alternatively, you can use a layer with noise applied (cranking up the levels a bit) to drive a Displacement Map effect.
Alternatively, if you get the noisy look inside that you like, but not on the edges, you could blur the edges and set the blending mode to Dissolve. 😀
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Lex Villena
August 25, 2018 at 12:58 amOkay, so a much faster way to achieve this effect (at least the noisey edges) is to just throw on a gaussian blur and then set the layer to dancing dissolve.
