Activity Forums Boris FX Particle Illusion Extreme Emitters- image sequences-change/swap images
  • Extreme Emitters- image sequences-change/swap images
    Posted by Randal Radabaugh on March 11, 2011 at 4:48 am
    hello.
    Been using PI3 on/off for almost 2 years, and recently got it for AE also.
    tbh, I never noticed the extreme emitters till now.
    have been looking all over for the answer to this:
    how to change the image sequence images in the extreme emitters?
    changing out/adding an image gives a single image- where as some defaults
    runs through 1-30.1-10 or none with multi images.
    cannot locate the default images in it either to swap.The video link on changing is not
    helpful.As an example- the Xray pulse 2.
    from this reply and link
    https://www.wondertouch.com/forum/index.html
    or this one
    file:///C:/Program Files/particleIllusion_3/Pro Emitters Manual/extreme_graphics.htm
    The Xray pulse2 has multiple images but no number seq
    – how do you add multiple images to the sequence? as in replace defaults?
    Also, on the ones such as fast numbers/letters that have numbers 1-10, 1-30 etc
    how do you swap out those images with different ones.
    default runs thru 1- 10 numbers. if I change/add image it flashes that 1 image 10 x?
    so if I have 10 images I want it to use- how?
    any links,tuts, answer would be “EXTREMELY” appreciated.
    also, keep seeing emit at points? have not found this parameter anywhere yet.
    Thank you.
    Randal Radabaugh replied 15 years, 5 months ago 1 Member · 1 Reply
