Activity Forums DaVinci Resolve Extreme difference between color in Resolve and exports?
  • Extreme difference between color in Resolve and exports?
    Posted by Brenna Perez on April 29, 2013 at 10:40 pm
    Hi all,
    I’ve recently run into a weird issue with my exports from DaVinci Resolve 9 (full version).
    I’m not sure if a random setting got switched, but I’m not really sure what to look for…
    Lately, I’ve been exporting color-corrected projects that have looked fine when played back on my computer (both on the calibrated panavision monitor as well as the normal, non-calibrated screen). As soon as we play the project back on another computer, or off a drive, it looks completely different (beyond the normal range between screens). So far, the color has been way darker, blacks completely crushed.
    I assume I changed something somewhere by accident, but I don’t know how to change it back.
    Any advice is greatly appreciated. Thanks!!
    William Edwards replied 13 years, 4 months ago 6 Members · 17 Replies
  • 17 Replies
  • Joseph Owens
    April 29, 2013 at 11:59 pm
    Check your “full range” or “linear video” settings. Extremely crushed blacks suggests that “0” is being mapped to some negative value in your playout… If 64-940 is being pushed out at 0-1023, but then being re-interpreted
    as if 64 is supposed to be at 0, then it will go below zero.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Brenna Perez
    April 30, 2013 at 12:02 am
    Thanks for the response!
    Currently set to 64-940 at 10-bit….
  • Laco Gaal
    April 30, 2013 at 6:32 am
    What kind of codec do you export to?
    What about your video output setting (video level, or data level?)
    At the render setting, be sure that “normally scaled” is selected.
  • Margus Voll
    April 30, 2013 at 7:07 am
    what i have seen lately is that if you export prorez you mostly get greenish tint.
    lets say if use uncompressed 10 bit rgb you get what you think you had.
    meybe it is just me but it seems this way for now.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Laco Gaal
    April 30, 2013 at 7:11 am
    even if you play back the exported prores in Resolve through Decklink?
  • Margus Voll
    April 30, 2013 at 7:13 am
    have not tested like this but opened in quictime.
    i have seen this on multiple machines but have not looked in to it as much as my stuff is
    not so big and 10 bit rgb serves me well.
    maybe it is SL thing?
    Margus
    Multibridge 2 Pro
  • Laco Gaal
    April 30, 2013 at 9:55 am
    I don’t really trust in quicktime player. For example if you export a H264 mp4 file, it will be always desatureted compared to Resolve SDI output/Resolve GUI/Opened with VLC.
    sadly:(
  • Margus Voll
    April 30, 2013 at 10:22 am
    actually h264 and prorez looked the same and i was doing web video.
    then i just took 10 bit rgb rout and it was all fine.
    Margus
    Multibridge 2 Pro
  • Hendro Setyo
    April 30, 2013 at 11:15 am
    Did you use any LUT setup to your monitor? May be the LUT wasn’t applied at your render?
    Not so sure what’s your exact settings are.
    Hendro Setyo W.
    Colorist
    VHQ Post (M) Sdn Bhd, Malaysia
    Setyo’s Reel Vimeo
  • Margus Voll
    April 30, 2013 at 11:45 am
    Hi.
    No luts as one format is fine and the other is not from the same project.
    At least i did not have.
    Maybe Brenna did have.
    Margus
    Multibridge 2 Pro
