Activity Forums Adobe After Effects Extreme color replacement
  • Extreme color replacement
    Posted by Samuele Gottardello on February 3, 2011 at 11:48 am
    Hello everybody, I’m super new here.
    I’m working (with AE) on a scene with a red scooter and the producer wants it white.
    the scooter is moving,
    so I’ve rotoscoped the scooter to isolate the red ares within the shot,
    I’ve tried 2 different ways but with no big success.
    1-hue/saturation effect: only in the reds channel I’ve lowered the saturation to -100 and the pushed the lightness to +100
    result–> medium grey
    2-change to color: from red to white, just Hue & Saturation and selecting Change To Color.
    result–> dark grey
    obviously I have to retain luminosity as I need the reflections on the paint.
    Is it possible to achieve a good result with a different way?
    thanks in advance for your help and have a nice day!
    Jim Arco replied 15 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tudor “ted” jelescu
    February 3, 2011 at 12:15 pm
    There is no way you can achieve white from red through color correction. It may become a lighter gray, but not white. The producer needs to understand that. If he/she wants a white scooter then he/she better be ready to get some considerable budget adjustments. The only way to do this and get a white scooter in there is to build a white scooter in 3d, match the camera move and lighting and then composite that back in.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Michael Szalapski
    February 3, 2011 at 2:31 pm
    Without a screen shot to play with I can’t offer much advice. You’d need to desaturate the red, then lighten it. Perhaps you could try putting levels or curves on it after one of your desaturation passes, but to be honest, I’m with Ted; it’s going to be difficult to get it right.
    I think you’d be better off reshooting. Depending on the complexity of the shot and the number of people involved it could be cheaper.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Samuele Gottardello
    February 3, 2011 at 2:54 pm
    let’s see if this image may help
    sorry I had to crop like everything ’cause the model is a new prototype.
    and this is also the reason because they can’t shoot again. the white prototype was destroyed like a month ago. very clever since now they need it to finish the ad.
    wooo!
    what I was asked to do is to change the red on the right with the “white” (actually is more or less a pale yellow) on the left.
  • Walter Soyka
    February 3, 2011 at 4:42 pm
    I’d be more inclined to attempt this with a color correction tool like Colorista II, but I absolutely agree with Tudor and Michael. You are being asked to pull a rabbit out of a hat.
    I’d approach this by pushing the colors away from red and towards yellow, and selectively desaturating warmer tones (to avoid completely desaturating the green and blue reflections). You’ll have to really crank the gamma on your midtones, which will show all kinds of ugly noise which must be reduced.
    Honestly, I wonder if there isn’t some other heavily-stylized creative approach to take to mitigate this work.
    Walter Soyka
  • Michael Szalapski
    February 3, 2011 at 5:26 pm
    Here’s a rough approximation of the effect:
    1587_scooter.psd.zip
    My machine with AE is in the middle of a render with Cinema 4d, but my web computer’s got Photoshop on it so that’s what you get. I only used effects you can get in AE though. 🙂
    On the hue/saturation layer’s edit drop down, choose red to see what I did.
    – The Great Szalam
  • Craig Whitaker
    February 4, 2011 at 4:31 am
    Last summer I had to paint a metal pole back into a scene for the same reason. What worked in the end was filling my root shape with a solid and painting in the highlights. Granted, it was a pole not a bike and it was only 20 frames, but it’s a least one approach. Best of luck.
    Craig Whitaker
    MFA Candidate
    New York University
    http://www.craigwhitaker.net
    February 4, 2011 at 9:59 am
    Please can you all explain this to my producer?
    this morning as I showed him my “poor” results he said:
    “Impossible! how can be so difficult?”
    (-__-)”
    anyway I really appreciate all your efforts, guys you really rock!
    special thanks to Michael Szalapski, so kind to send a psd.
    let’s say that I’m kinda close to a “not so bad at all” solution, thanks to you guys!
  • Jim Arco
    February 6, 2011 at 1:25 pm
    Whenever I need to do extreme color corrections, I convert to L-a-b color space and work in the ‘a’ and ‘b’ channels. In this case, the color of interest is red, so you would be using some extreme curves in the ‘a’ channel.
    Since AE doesn’t provide an option for L-a-b color, you’d have to open the footage in Photoshop, convert to smart object, then switch to L-a-b color space and work on the ‘a’ channel there.
    …..admittedly a long-shot, but might be worth a try.
    Jim
