Activity Forums Blackmagic Design Extreme card not playing back HD and HDV anymore
  • Extreme card not playing back HD and HDV anymore
    Posted by David Roth weiss on June 27, 2006 at 7:12 am
    I used to be able to monitor HDV in realtime through my Extreme card via component out on my SD broadcast monitor at eith 8-bit or 10-bit resolution. That no longer works, it only updates when I hit stop on FCP. And, I just got in a film project on DVCPro100 that I’d also like to be able to display to my SD monitor, but I’m encountering the same problems. Anyone have an idea???
    THNX,
    DRW
    Peter Sassi replied 20 years, 2 months ago 3 Members · 3 Replies
  • Kristian Lam
    June 27, 2006 at 7:58 am
    Most likely a setup issue.
    Best way is to use the easy setups we provide (Final Cut Pro > Easy Setup). Then verify that in View > Video Playback matches your easy setup.
    The same thing applies to playing your DVCPRO HD clip. Select the matching easy setups, then create a new sequence and drop your clips into it. You have to create a new sequence as easy setups do not affect existing ones.
    regards
    Kristian Lam
    Blackmagic Design
  • David Roth weiss
    June 27, 2006 at 8:20 am
    Wow Kristian, that was fast… I got it to work, but only with a strange View > Video Playback that strangely does not seem to match my setup. Tomorrow a.m. when I get back into the edit bay I’ll post the one that works and maybe you can tell me why. I can’t remember exactly the one, but its ceratinly not the logical choice.
    THNX,
    DRW
  • Peter Sassi
    June 28, 2006 at 3:04 am
    David,
    I had the same thing. Only the only way i could get playback was to uninstall BM and reinstall. Ver. 5.6.
    Let me know if you get a “reliable” setup. For me, the same setup (not there now) that did not work, did work after i reinstalled the BM drivers. Someone posted about the latest ProApps update from Apple crashing BM. I have not been able to confirm this.
    Regards,
    Peter
