Activity › Forums › Apple Final Cut Pro Legacy › Extrecting from DVD and VHS
  • Extrecting from DVD and VHS
    Posted by Diana O’gilvie on June 30, 2006 at 9:00 pm
    Good Day All,
    Can anyone tell me how to extract/import footage from a DVD? FCP HD is giving me access to few .vob files but not the entire DVD. Regarding the VHS tape I am getting no access whatsoever. I am using a JVC deck and I switch it from DV to SVHS but FCP is not regocnizing it. Any advice will be greatly appreciated. Thanks in advance.
    Best Regards,
    Di
  • Ed Dooley
    June 30, 2006 at 9:30 pm
    For the DVD part, do a search of posts, it’s been discussed lots and lots.
    Ed
  • Bouncing Account needs new email address
    June 30, 2006 at 9:59 pm
    [Dianao] “I am using a JVC deck and I switch it from DV to SVHS but FCP is not regocnizing it.”
    If you are using a “DUAL” VHS/DV Deck, the VHS tapes will not play down the FireWire (only the DV tapes will do that).
    You should first dub the VHS to a DV tape, then capture the DV tape into FCP.
    As for DVD imports:
    Here are 3 popular rippers.
    https://www.dvdxdv.com/
    https://www.miraizon.com/products/products.html
    Mpeg SlipStream is very popular, Found at the following link>
    https://www.squared5.com/
    As Ed said,if you’re in a hurry, you can find answers to most questions in seconds with the “Search Posts” here on the COW.
