Activity Forums Adobe Premiere Pro Extracting timecode to a text file or xml (Premiere CS4)
  • Extracting timecode to a text file or xml (Premiere CS4)
    Posted by Wil Conklin on July 6, 2010 at 7:34 pm
    Hi all. I’m working on a series of projects that require me to pull the timecode from certain points in a clip while I’m editing said clip. These pulled timecode will eventually be put into an xml file for captioning purposes in flash. I was wondering if anyone would know of an easy way to pull the timecode of the pointer’s location to an xml file (or text/excel sheet). If not the pointer location, maybe pull marker locations into an xml file (or text/excel).
    Thank you in advance!
    Wil
    Sam Stevens replied 15 years, 10 months ago 2 Members · 3 Replies
  • Sam Stevens
    October 29, 2010 at 11:07 am
    Did you ever get anywhere with this? We’re trying to do something similar, just extracting timecode from source footage into xml files and have hit a bit of a brick wall now.
  • Wil Conklin
    November 1, 2010 at 5:07 pm
    Hi Sam, I finally did find a solution using another users post, using AutoHotKey. Found here.
    https://forums.creativecow.net/readpost/3/901537
    I modified the code a bit to spit out the xml I needed. If you like, get me your e-mail address and I’ll send the AutoHotKey script I use to you. (Apparently I can’t post it on the forum because it strips the xml tags out.)
    Wil
  • Sam Stevens
    November 1, 2010 at 5:13 pm
    That would be great, thanks Wil – you can get me on sam.stevens@lightningfishgames.com
    Much obliged,
    Sam
