Activity › Forums › Compression Techniques › extracting images
extracting images
Posted by Peter Robertson on April 7, 2012 at 10:41 pmIs there a way to extract say 900 frames at intervals of 4 minutes for a video that is 1 hour long so that the output could then be used to create a new (shorter) video?
Pedro
Peter Robertson replied 14 years, 5 months ago 2 Members · 2 Replies -
Stephen Dixon
April 9, 2012 at 3:29 pmfrom the ffmpeg online manual:
This will extract one video frame per second from the video and will output them in files named ‘foo-001.jpeg’, ‘foo-002.jpeg’, etc. Images will be rescaled to fit the new WxH values.If you want to extract just a limited number of frames, you can use the above command in combination with the -vframes or -t option, or in combination with -ss to start extracting from a certain point in time.
I’m not sure if it will work with numbers other than integers, but you could try using r -0.0001667 (I had a test with ffmbc and even -r 1 didn’t work so YMMV)
Or you could use the shell with a loop and a variable to just extract 1 frame at a given time. I’m not sure what environment you’re in, but with bash on linux/os x you’d do something like:
for i in {0..900};
f=$(( i * 240 )) # (240 because it's 60 seconds * 4)
done -
Peter Robertson
April 11, 2012 at 5:56 pmI’m using a windows command line–I’m not sure what the syntax would be for the above???
Thanks.
Pedro
