Activity › Forums › Adobe After Effects › Extracting image sequence from MP4 movie file
  • Extracting image sequence from MP4 movie file
    Posted by Stephen Patience on November 18, 2015 at 11:11 am
    Folks,
    Just got the new DJI Osmo. It does great time lapse, but makes it onboard the camera as an MP4 file, ready to use instantly.
    My issue is I want to edit the images as a sequence and tone map the images as a sequence. That means converting the movie back into jpgs or tiffs etc.
    Does After Effects do this easily does anyone know?
    Thanks for tips / advice.
    Stephen
    Michael Szalapski replied 10 years, 10 months ago 3 Members · 2 Replies
  • Daniel Waldron
    November 18, 2015 at 2:53 pm
    You can export a png, tiff, or jpeg sequence from After Effects. It won’t be the original images from the camera of course, but it will give you the individual frames to work with.
  • Michael Szalapski
    November 23, 2015 at 7:51 pm
    Although, I would use the Adobe Media Encoder to do this rather than After Effects.
    You should check to see if your camera has an option to record in a different format though. An MP4 file is going to be highly compressed and it uses interframe compression which you probably don’t want.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
