Activity Forums Apple Final Cut Pro Legacy Extracting from a DVD which codec should I use for FCP ?
  • Extracting from a DVD which codec should I use for FCP ?
    Posted by Fredy Schwerdtner on June 2, 2010 at 5:59 pm
    Hi fellows,
    First, unfortunatly I have to say that I got a storm over here: My MBP is dead …. it is at Apple to fix it and I’m afraid it is the mother board … snif.
    As I can’t have a privilege to be stoped doing nothing, I got a little job. A client brought me 2 DVDs and he wants to make 2 little trailers of the movies to be posted on his website and in another DVD. He doesn’t have the masters, so I will have to extract from the DVDs. I’m planing to use MPEG Streamclip to do it. The movies are regular 4×3. I believe I should make the movies as DV instead of Quicktime. Said that, MPEG Streamclip gives 3 options: DV, DVCPRO25 and DVCPRO50. Which one should I use since I’m already making a material from a compressed file ?
    Thanks in advance.
    Fredy
    PS.: I will be working on my old iMac 800 with FCP 5 or 6
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.5.7
    Final Cut Studio 2
    Matt Campbell replied 16 years, 3 months ago 3 Members · 3 Replies
  • Michael Sacci
    June 2, 2010 at 6:08 pm
    I use DVCPro50 or prores, It will hold together better when it is compressed for the other DVD. Not a huge difference but enough to make it worth taking up the extra HD space.
  • Fredy Schwerdtner
    June 2, 2010 at 9:08 pm
    Thanks Michael,
    If I go for FCP 5 I will make the movies DVCPRO50 because FCP 5 doesn’t hold PRORES but if I go for FCP6 I will go for PRORES.
    Thanks again …
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • Matt Campbell
    June 3, 2010 at 6:11 pm
    I do this all the time and use ProRes. Works and looks good. Just make sure you keep your frame rates in order.
    OS 10.6.3, Mac Pro 2 x 2.66 ghz quad-core intel xenon, 16 gb ram, with BM Intensity Pro card
