Activity Forums Adobe After Effects Extracting Corner Pin tracking data from a stabilize tracked layer
  • Extracting Corner Pin tracking data from a stabilize tracked layer
    Posted by Jim Bachalo on July 22, 2011 at 12:24 am
    Hi
    I have a stabilize tracked layer.
    I need to extract corner pin tracking data from this layer( a brick wall that changes perspective) to another layer (to match the changing perspective)
    Whats the best way to do this? Do I need to precompose the stabilize tracked layer first BEFROE extracting corner pin data or…?
    Local is the new global
    Barend Onneweer replied 15 years, 1 month ago 2 Members · 1 Reply
  • Barend Onneweer
    July 22, 2011 at 6:33 am
    The general rule of thumb is to motiontrack the raw source footage, to avoid mangling the pixels before tracking.
    So in that case what you’d do is corner-pin track the source footage, comp in your elements and then stabilize the endresult.
    But depending on the footage you could also try to corner-pin track the stabilized result – it’s just a less clean workflow.
    I’d advise you to do the tracking in MochaAE.
    Barend
    Raamw3rk – digital storytelling and visual effects
