Activity Forums VEGAS Pro extracting a wav file from a project
  • extracting a wav file from a project
    Posted by Eric Adler on July 24, 2007 at 8:49 pm
    I have a HD project on the timeline. The audio is burdened with a lawnmower in the backround that I wish to filter out using adobe audition. how do i extract the wave file from my project timeline?
    Also I am having trouble getting rid of my direction vocals in the audio. I tried cutting from a selection of clean backround noise but it seems to cut the video as well so when I paste the clean noise over the selection of my voice it also pastes the video.
    b.
    Janet Turner replied 19 years, 1 month ago 3 Members · 2 Replies
  • Edward Troxel
    July 24, 2007 at 10:07 pm
    File – render as – pick WAV as the file type.
    Edward Troxel
    JETDV Scripts
  • Janet Turner
    July 25, 2007 at 3:28 pm
    I would suspect the reason you are having problems with the audio is because the video/audio are in a group. In order to edit them separately, you have to ungroup them. To do this, highlight the audio clip, right click on it and a menu will come up. Check remove from group. Now when you edit the audio, it will not cut the clip. Be sure your auto-ripple option in the toolbar is not active and then you can slice and dice to your hearts content. Once you make your changes, be sure to add everything back to a group or your audio will be out of sync should you make additional changes to your clip(s).
    Hope this helps.
    Grasshopper
