Activity Forums Audio Extract surround sound
  • Extract surround sound
    Posted by David Gruwier on December 6, 2011 at 4:07 pm
    I have a video file with 6 channel surround sound, and I need to extract the audio as separate files. I’ve tried a few converters, including SUPER, but none of them lets me extract more than 2 channels, unless I use a format like AAC or AC3 that supports surround (but doesn’t work with any of my editors). So is there a tool or technique for extracting surround sound, preferably as multiple mono or stereo .wav files?
    David Gruwier replied 14 years, 9 months ago 3 Members · 6 Replies
  • André Engelhardt
    December 6, 2011 at 4:19 pm
    Hi David,
    it’s hard to give an exact answer as it depends on the source format. Could you tell us what the original video container is? (Such as .mov, mpeg etc) and then maybe what you intend to do with it as that can influence workflow.
    Audio Engineer, Sound Designer
    Video- and Photographer
    http://www.andreengelhardt.net
  • David Gruwier
    December 6, 2011 at 7:09 pm
    It’s an .mkv using the H.264 codec, and the audio is AC-3, but I can convert it to pretty much anything with an audio format that supports surround sound.
    I need to edit a couple of the channels individually. The final mix will be stereo.
  • André Engelhardt
    December 6, 2011 at 9:31 pm
    I’m assuming you’re using Windows so a quick google search (since we’re running Mac only here) found me two apps that will do the job for you as it seems:
    1.) Smartlabs tsMuxer will be able to extract the AC3 out of the .mkv Link: https://smlabs.net/en/products/tsmuxer/
    2.) Using BeSweet you will be able to grab the ac3 and spit out separate files Link: https://dspguru.doom9.net/
    Hope that helps, good luck! 🙂
  • Peter Groom
    December 7, 2011 at 2:03 pm
    Speaking as someone who mixes and therefore creates surround productions , that ultimately end up as ac3 files etc on dvds, Id suggest that theyre in that format because people, just like me, dont want you accessing the components.
    If youre supposed (and have permission) to do it then the owner of the work will be able to arrange whatever deliverables you need. If you dont have that permission……….
    Dangerous territory.
    peter
    Post Production Dubbing Mixer
  • David Gruwier
    December 7, 2011 at 9:43 pm
    I don’t have any permission, it’s purely for an exercise. As far as I know, it should be fine as long as I keep it private?
    It probably wouldn’t be in .mkv if it was for editing either.
  • David Gruwier
    December 7, 2011 at 9:46 pm
    I’ll try these out, thanks :-).
    //David
    ____
    https://clearcutgames.net/
