Activity › Forums › Apple Final Cut Pro Legacy › extract every fifth frame
Posted by Jayson Rahmlow on April 19, 2008 at 5:18 amHello,
Is there a way in FCP or Avid MC to reduce a clip to only every fifth frame like:frame#1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,etc.
would become
frame#1,6,11,etc.
thanks,
jayson
http://www.oldchildprojects.comArnie Schlissel replied 18 years, 5 months ago 5 Members · 12 Replies -
Zane Barker
April 19, 2008 at 5:36 amYou can use Quicktime Pro to export a image sequence and then create a smart folder to only show you the images that contain a 0 & 5 or what ever you choose.
Then as far as I know the easiest way to assemble them into a quicktime movie would be motion, it has a easy way to play back a image sequence.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Jeremy Garchow
April 19, 2008 at 5:44 amStobe filter set to 5?
Effects > Video Filters > Video > Strobe
Jeremy
Zane Barker
April 19, 2008 at 5:45 ameven better
Nick Meyers
April 19, 2008 at 5:58 amyou can speed the clip up by 500% to achieve this.
FCP will generally give you an *aproximation* of the speed you request
the real trick with this, if you need accuracy, is to start with a number that deides evenly by the speed you need to apply.your clip for instance should be a number of frames that is divisible by 5.
right or control click in the TC fields in the viewer, canvas & timeline and choose “Frames”
now you can see your duration in frames.
adjust the duration of your clip to be 5-friendly,
and change the speed (Apple J) to 500%turn frame blending OFF
nick
Jayson Rahmlow
April 19, 2008 at 7:25 amThanks for the suggestion Jeremy. I gave it a try but it’s not exactly what I was looking for. It stretches out the frames to replace the others so:
frame# 1,2,3,4,5,6,7,8,9,10,etc.
effect>video filter>strobe – set to 5 becomes
frame# 1,1,1,1,1,6,6,6,6,6,etc.
and I want it to go
frame# 1,6,etc.
am I using it wrong?
Nick Meyers
April 19, 2008 at 7:40 amyou are using it right.
that’s what the strobe filter does.you want to adjust the SPEED of the clip.
(as outlined in my previous post)nick
Jeremy Garchow
April 19, 2008 at 7:42 amIt was just a guess. Sorry.
Nick’s suggestion is spot on and Zane’s will work too.
Jayson Rahmlow
April 19, 2008 at 7:43 amnick that was great, it worked. And I’m definitely looking for accuracy. I got the idea from Shake’s global range setting. Where you can type in 1-16×5 and then it’ll render a flipbook with the frames 1,6,11,16. Would like that for FCP.
and thanks for the switching to frames TC tip. It’d be nice to be able to bind that to a key.
jayson
http://www.oldchildprojects.com -
Jayson Rahmlow
April 19, 2008 at 8:04 amHi Zane,
thanks for the suggestion. It sounds like a good way to really control which frames make it into the clip. If I want to replace a 4th frame instead of a 5th frame every once in awhile.I’m giving it a try but I’m new to smart folders and I don’t know how to search for files containing “1.png” and “6.png” Do you know how to do this?
thanks,
jayson
Arnie Schlissel
April 19, 2008 at 8:13 pmI was going to recommend Shake for this. You would use a Time-x node, I think, but it seems you already have a grip on it.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
