Activity Forums Adobe Premiere Pro Extract Edit / Playhead position
  • Extract Edit / Playhead position
    Posted by Enno Jacobsen on May 13, 2011 at 12:12 am
    I am learning my way around Premiere Pro (after editing in FCP for years). I have a superbasic question: When I am making an “extract edit” in the timeline, the playhead doesn’t snap to the position of the cut, but stays at the same place in the timeline, while the clips are cut and move to the left of the playhead. Now, if I want to review the cut, I have to move the playhead to the cut and play from there. (When you make an extract edit in a Final Cut Pro timeline, the playhead would snap to the cut after the extraction of the material.)
    I am not sure if this is a setting in the preferences or if it simply is clumsy programming.
    Does anyone have the same issue or knows how to fix it?
    Enno Jacobsen replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
