Activity › Forums › Apple Motion › Extra keyframes in Motion 5
  • Extra keyframes in Motion 5
    Posted by Marv Cam on January 3, 2014 at 4:21 pm
    Hi everybody!
    I just moved from Motion 4 to Motion 5, and Im having a hard time with the keyframes. Motion 5 is creating new keyframes even if the record button is off. This is a problem when I want to modify the original position or size of an object, Motion 5 considers this change as a new movement and creates a new key-frame. The past version of Motion didn’t do this.
    Can somebody help me out?
    -Marvin-
    Möller Publicity Agency
    Producer
    Heintje Fernandez replied 11 years, 1 month ago 3 Members · 4 Replies
  • Marv Cam
    January 3, 2014 at 4:35 pm
    I tried double clicking the record button and a menu appeared none of those options worked.
    Producer
  • Robin S. kurz
    January 3, 2014 at 5:38 pm
    Yes, I know what you mean. I’m not terribly excited about the change either, but it was (unfortunately for us Motion old-timers 😉 done to work like FCP X (I’m guessing) so as not to confuse newcomers i.e. people coming to Motion from FCP X for the first time. Which also explains the disappearance of the “Record only for animated parameters” option in the record options window. 😉
    To move an object and maintain the keyframes’ relative position without creating (a) new one(s), you need to hold the ⌥ and ⌘ keys.
  • Marv Cam
    January 7, 2014 at 5:14 pm
    Thank you for commenting, but that didn’t work.
    I really don’t understand why they mess with the principles of animation, this software has disappointed me so far. Thanks again thou.
    Producer
  • Heintje Fernandez
    August 8, 2015 at 4:09 am
    It did work for me…you have to steady click on the image that you need to change, press command and option then try moving it…hope it works for you now.
