Activity › Forums › Blackmagic Design › Extra frames appearing on edit to tape.
Chee Wee wee tan replied 19 years, 5 months ago 7 Members · 11 Replies
Chee Wee wee tan
March 6, 2007 at 5:25 pmActually i think this can be easily solve.
You need to adjust the RS422 control, what is happening is that the video are cutting in too early, 1 frame too early infact and your FCP has not even start to play the video.
CMD-OPT-Q at FCP and select “Device Control Presets”, create a new Preset and adjust it’s “Playback Offset” until you get frame accuracy.
I recommend tick “Use Deck Search Mechanism” also.
This probably occurs because the RS422 cable and the video cables are of significant different lengths in the facility.
Good luck!
tcwdoggy
http://www.tcwdoggy.com
