Activity Forums Boris FX Extra frame being added
  • Extra frame being added
    Posted by Andrew Beavis on March 4, 2016 at 1:42 pm
    HI, I am using Corel Videostudio X9.
    When I upload a 10 second video to Boris it creates an extra frame for some reason.
    i.e The video then lasts a duration of 10.01
    This is messing with some of the effects as I need the video to loop.
    It wouldn’t be so bad but when I add a track media clip to the project it will add it as the correct 10 seconds.
    Hope that made sense.
    Any help would be appreciated.
    Cheers
    Jon Kozenko replied 10 years, 5 months ago 2 Members · 1 Reply
  • Jon Kozenko
    March 8, 2016 at 11:11 pm
    Hello Andrew,
    In Graffiti, you will see a frame at the very end that would not exist, but this should only be a preview frame, and shouldn’t appear once you Apply back to your Host. Have you noticed the problem after Applying back and performing the clip as a loop? One thing you can try would be to move the final Keyframe(s) back one frame to off-set this extra frame.
    Hope this helps.
    Thanks.
