Activity › Forums › Blackmagic Design › External video static. Seen but not moving. Help!
  • External video static. Seen but not moving. Help!
    Posted by Vintagemurray on January 5, 2006 at 7:27 pm
    I’ve got a Decklink HD Pro and I’m outputting component analog to my reference monitor. The image is there onscreen but does not play when FCP plays the clip. It updates to current frame when clips stops playing. Any ideas?
    G5 dual 2.0
    2 gigs ram
    G-raid 500 firewire 800
    Thanks in advance.
    Olivier Jean replied 20 years, 9 months ago 2 Members · 1 Reply
  • Olivier Jean
    January 6, 2006 at 1:05 pm
    WE need a little bit more info…
    Which G5 is this has it got a pci-x se you got lot?
    was it working before?
    did you use the easy setups?
    Have you got your view/monitor/all frames selected?
    is you canvas frame size bigger than the canvas window??
    we need more info.
    Regards
    Olivier Jean
    Video Sales Consultant
    Apple Certified Trainer Final Cut Pro 5
    Powermedia Systems
    Sydney Australia
