Activity Forums Apple Final Cut Pro Legacy external video problem
  • external video problem
    Posted by Florian Herweg on April 27, 2007 at 4:08 pm
    hi
    when i want to view my footage on an external monitor i just see a the still frame where i started to play … when i stop the playback the monitor updated the still frame to where i stoped the playback … the weird thing is that it worked perfect before … but after i cleaned up my mac from scratch and reinstalled tiger and fcp it stoped working!
    i’m using fcp 5, a blackmagic decklink HD extreme, g5 dual 2.7ghz
    the footage i’m editing is 720p24 .. the external monitor is a sony sd screen
    even with plain ntsc footage i got the same problem!
    anybody got a solution?
    best
    flow
    Randall Packer replied 15 years, 10 months ago 7 Members · 8 Replies
  • 8 Replies
  • Billy Stuart
    April 27, 2007 at 7:44 pm
    Flow-
    Check View>external video>all frames.
    see if that helps
    Billy Stuart
    Post Supervisor
    National Boston Video
    617.734.4800
  • Florian Herweg
    April 27, 2007 at 8:19 pm
    sorry for not mentioning it before but i checked it of course!
    just to let you know another detail: the canvas is playing fine! just the external video playback is frozen!
  • Debe
    April 28, 2007 at 5:12 am
    Canvas size set to “Fit to Window”?
    debe
  • Florian Herweg
    April 29, 2007 at 1:04 am
    also did that … but didnt work!
  • Charlieberk
    May 2, 2007 at 8:05 pm
    I’m having the same problem – I get still frames on my high def monitor at the begining and ending of the selected clip- it doesn’t display continuous video. Have tried everything – including “ALL Frames” and setting the monitor preferences with no luck.
    Do you have an answer on this yet?
    Sandy
  • Russell Lasson
    May 2, 2007 at 8:58 pm
    Which Blackmagic Video output are you using?
    With 720/24P you should select View-Video Playback-Blackmagic HDTV 720P 59.94 – 8-bit (1280×720)
    If you’re using 10-bit uncompressed, then you should change it to 10-bit instead of 8-bit.
    Why not use the 23.98 setting? Because it doesn’t work that way. (It might with some monitors, but with my Sony PVM HD monitor, it doesn’t.)
    -Russ
  • John Hunter
    November 6, 2008 at 3:07 am
    I’m having the same problem! I’m using a Samsung LCD HDTV connected to my G5 via a DVI/HDMI cable. I have it set to Digital Cinema Desktop Prview-Full Screen and then hit “apple F12” for ALL FRAMES. All I get is a still of the frame I hit play on and a still of the frame that I stop on.
    Now it is even doing it when I turn the LCD tv off and just use the HD Apple Cinema Display monitor.
  • Randall Packer
    November 13, 2010 at 12:33 am
    I was able to resolve this problem by correcting the frames per second. I accidentally created the wrong fps in the sequence settings. This may be specific to my own mistake but possible of interest to anyone having this problem.
