Activity Forums Apple Final Cut Pro Legacy External video playback displays only when paused or scrubbed
  • External video playback displays only when paused or scrubbed
    Posted by Adam Yeremian on June 24, 2008 at 8:10 pm
    I am using a Sony DSR-11 deck connected to my computer through firewire and to my Samsung Digital Television using A/V components.
    The external video display seems to work only when my playhead is paused or when I scrub around on the timeline. It does not display playback in real time when I press the play button or spacebar.
    I have made sure that all my settings and preferences are working properly and still can not find a solution to this problem.
    Thank you in advance,
    Adam
    Chris Borjis replied 18 years, 3 months ago 4 Members · 4 Replies
  • Joseph Langdale
    June 24, 2008 at 9:13 pm
    Check under the “View” menu that the “External Video” submenu that “all frames” is checked. Or you can try “apple key” f12.
  • Adam Yeremian
    June 24, 2008 at 9:31 pm
    Yes, I had this checked off. Still didn’t work properly…
    thank you for your response though
  • Ben Holmes
    June 24, 2008 at 10:14 pm
    Adam
    You must have your external video on if you are seeing some frames. What you describe happens when the sequence video settings and the output device settings don’t match.
    Using firewire, you can only send DV video, so check that’s what the sequence uses. Try capturing again from your camera, and dropping this capture into a new EMPTY timeline/sequence. When FCP asks if you want to match the sequence settings to the clip settings, hit ‘yes’.
    Make sure this plays ok – if it does, either compare the sequence settings here to your other sequence, or just copy and paste all the clips from your ‘bad’ sequence into this new one.
    Hope that helps.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Chris Borjis
    June 24, 2008 at 10:23 pm
    having a sequence at 30 fps instead of 29.97 fps does this as well.
