Activity Forums Apple Final Cut Pro Legacy external video not working
  • external video not working
    Posted by Renee Bergan on November 29, 2005 at 9:23 am
    So i was editing in FCP 5.0 on OS 10.3.9 on my powerPC G4 1.33 ghz. It was acting clunky and jerky..so i upgraded to 10.4.3 (i was told FCP 5 works better with 10.4 over 10.3). now lo and behold, fcp 5 no longer recognizes my deck. that part was all working fine before. I tried different FW cables and different FW ports (even bypassing my drives and trying straight from the computer–besides the drives are recognized so it’s not the ports)…no go…even tried different cameras/decks. What the @#$%^&* is going on?
    I’ve tried refreshing my av decks and it still tells me my apple FW NTSC is missing.
    ARGH.
    Cardinalman replied 20 years, 9 months ago 5 Members · 6 Replies
  • Martin Phillips
    November 29, 2005 at 10:13 am
    One of FCP’s little anomolies!
    In FCP go to View / External Video / then select All Frames
    Should sort it out
    Martin.
  • Renee Bergan
    November 29, 2005 at 10:42 am
    Already tried that…problem is just below that option under View, and Video Playback…it tells me that my FW option is missing. Yet i’m all plugged up and ready to go as i had been before i installed os x .4….any other ideas??? would love it to be something simple –due to poor brain cells this late in the evening, but i’m scared it’s something bigger.
  • Bouncing Account needs new email address
    November 29, 2005 at 10:47 am
    Try looking here:
    https://docs.info.apple.com/article.html?artnum=301852
    This seems to be the answer to many of these kind of problems.
  • Frank Nolan
    November 29, 2005 at 10:50 am
    There have been a few instances of this after upgrades so apple has posted a fix it on their website.
  • Renee Bergan
    November 29, 2005 at 11:48 am
    THANK YOU!!!
    i had a feeling it was something like preferences or what not….
    you saved my sanity tonite.
  • Cardinalman
    December 1, 2005 at 6:06 pm
    I have the same problem. I can’t select all frames. I’ve tried everything I’m using G5 fcp5 sony hvd fx1. I need to know what I can do in prefs that will allow me to see the video on my camcorder. I’ve been at this for hours and seem to be stuck in a loop. Please help
