Activity Forums Adobe Premiere Pro external video monitoring
  • external video monitoring
    Posted by Jim Scott on January 4, 2011 at 5:37 am
    I have a Mac Pro with a Blackmagic Design Intensity Pro card. Though I have searched the manuals for it and Premiere Pro CS5 I can find no way to monitor video on an external monitor from Premiere like I can with After Effects and Final Cut Pro. Is this possible? And if so how do I configure it?
    Dane Cannon replied 14 years ago 5 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    January 5, 2011 at 4:52 am
    Here’s the relevant portion of the Premiere Pro documentation, and there are setup instructions for various configurations here, but the details are something that you should be able to get from the BlackMagic documentation.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jim Scott
    January 5, 2011 at 5:16 pm
    Thanks Todd. I have tried doing exactly as the Blackmagic documentation specifies (which is rather lacking) with no success. For some reason I do not have an option in Premiere to select a Blackmagic output source though the Blackmagic presets are installed. I have written to Blackmagic for help.
    Thanks again.
  • Jeff Pulera
    January 5, 2011 at 5:58 pm
    Hi Jim,
    I haven’t used the Intensity, but did recently try the Decklink HD Extreme, and BlackMagic supplies a little utility where you actually set up the inputs and outputs outside of Premiere, maybe Intensity is the same and you need to run that to correctly route the output format and connection to your display?
    Don’t remember the name of program, but look in Programs > BlackMagic and see what you find
    Jeff Pulera
    Safe Harbor Computers
  • Jim Scott
    January 6, 2011 at 12:20 am
    Thanks Jeff, I’ll look into that.
  • Jim Scott
    January 6, 2011 at 12:29 am
    In setting up a new project I had neglected to properly select a Blackmagic preset. Once I did that I got external video preview just fine.
    Thanks again.
  • Jon Shearburn
    January 5, 2012 at 8:29 pm
    I hate to be that guy, but can someone walk me through this? The Adobe and Blackmagic documentation is useless. I’ve been trying every project/sequence/codec cocktail I can think of and I CANNOT get video to my external monitor and the director and client are getting very upset with me.
    I’m running a Mac Pro with OS 10.6.8 and Premiere CS5
    https://www.jonnyres.net
  • Dane Cannon
    September 11, 2012 at 9:27 pm
    You have to make a new sequence and choose to use a Matrox sequence preset (if you’re using Matrox gear, Blackmagic if you’re using BM etc.). Also, be sure to check the video card developer’s website to make sure that the driver is up to date and the software version you’re running is supported by the installed driver.
