Activity Forums Adobe Premiere Pro External video monitor w/ new Mac Pro
  • External video monitor w/ new Mac Pro
    Posted by Bob Dorough on December 5, 2014 at 6:33 pm
    Just set up a few new trash cans in edit suites with two Apple displays on each. Will be using Premiere Pro to edit. I have a large HMDI monitor for client viewing in each suite. I plug that into the HMDI slot on the Mac Pro and it shows up as a third desktop. I don’t want this – I want it to exclusively show my video output from PP. Do I need to change my setup or am I missing a hardware component? Thanks in advance!
    Gavin Mcglynn replied 11 years, 2 months ago 4 Members · 4 Replies
  • Shane Ross
    December 5, 2014 at 7:28 pm
    Missing hardware. Video IO device from AJA.com or blackmagicdesign.com. Cheapest solution is the Decklink Ultrastudio Mini Monitor from blackmagic.
    https://www.blackmagicdesign.com/products/ultrastudiothunderbolt
    But AJA also has the T-TAP, and in my experience, AJA is slightly more solid, plus they have great tech support. Worth the little extra you pay…and that’s why you pay a little extra.
    Shane
    Little Frog Post
  • Bob Dorough
    December 5, 2014 at 7:32 pm
    Thanks, Shane. I actually figured it out just now. Premiere Pro has Playback options in the Preferences menu. That allowed me to select which monitors to send video out to.
  • Eric Santiago
    January 23, 2015 at 7:35 pm
    Just got a hold of a Sony PVM X300 for demo.
    Ive been wanting to test a 4K display from an UltraStudio 4K.
    Great luck with FCPX and Resolve with both HD-SDI and HDMI at UHD res.
    REDCINE not so much, just crashes.
    It does work via Rocket not sure why it craps out through UltraStudio.
    Now my real problem.
    I cant get this to work with Premiere Pro CC 2014.
    Ive updated the DesktopVideo to 10.3.5 (latest) and everything else works except for Premiere?
    Ive set the BMD as Playback in Prefs and turned everything on that was working before updating to CC.
    Last known Video Output for us with Premiere was CS6 and DeckLink Extreme.
  • Gavin Mcglynn
    July 6, 2015 at 4:38 pm
    How did you figure this out? I’m having the same issue and I can’t figure it out. Checked the mercury transmit option in preferences>playback but nothing is working. Thanks!
    Basically just trying to avoid buying an video I/O card, but it looks like I will need one anyways for Resolve.
