Activity › Forums › Apple Final Cut Pro Legacy › External Video can’t switch to “All Frames” in FCP 5
Posted by Christopher Bagnall on November 30, 2005 at 2:44 amFor some reason I can not switch to All Frames in FCP5 which I recently upgraded to. It just sticks there. I’ve even deleted and reinstalled the entire program. Nothing was changed. What’s strange is that from my Log and Capture window, I can control my Sony Camcorder which is being used as my bridge. Whether it’s Non-Controllable Device or Firewire NTSC, neither work but I can play, fwd, rew, stop, etc from the Log and Capture window without picture or sound. Anyone run in to an error like this or know how to fix it? Thanks
Dan Riley replied 20 years, 10 months ago 3 Members · 2 Replies -
Rob Forsythe
November 30, 2005 at 3:23 amThis list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729AND… with a FCP5 install there is THIS to check:
https://docs.info.apple.com/article.html?artnum=301852
>Then, start again at my “step 1” above.
Dan Riley
November 30, 2005 at 3:40 amYou need to go through your input settings.
FCP is obviously seeing the firewire device or your could not
control it. But you don’t have the video and audio inputs
selected correctly. You aren’t going to be able to set your
external video to “all frames” unless FCP sees that you have
a video output device connected. FCP doesn’t think
you have one. From the Final Cut Pro menu, go to
audio/video settings. Look over all the settings
and see if everything is looking at your Sony Camcorder.
What happens if you play a clip or sequence?
Does it play out through your firewire device to your NTSC monitor?Dan
