Activity Forums Apple Final Cut Pro Legacy External SATA/FW Enclosure recommendations?
  • External SATA/FW Enclosure recommendations?
    Posted by Paul Huppe on May 23, 2007 at 6:56 pm
    Can anyone recommend anything in the way of a Hot-Swap External Enclosure that has both SATA and Firewire 800?
    I’ll be cutting on a MacBookPro 17′ and want to be able to copy files from/to a desktop FCP (thus the FW800), yet want the speed of SATA for 8bit uncompressed editing (running off a WieBeTech Express34 SATA card).
    Paul
    Shane Ross replied 19 years, 4 months ago 2 Members · 3 Replies
  • Shane Ross
    May 23, 2007 at 7:00 pm
    Firewire 800 units like the G-Raid 2 and Firewire VR will allow you to edit uncompressed 8 bit just fine.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Paul Huppe
    May 24, 2007 at 5:56 pm
    Thanks Shane,
    Yeah, that would be the way to go for sure; however I’ll be capturing using the AjA IO Firewire box, so will need to go SATA to free up the connection. I just can’t seem to find a SATA solution that also has a firewire connection.
  • Shane Ross
    May 24, 2007 at 6:13 pm
    G-Drive Q. USB 2.0, Firewire 400, 800 and eSATA.
    Shane
    Littlefrog Post
    http://www.lfhd.net
