External Samsung SSD for AE Cache on iMac
Hi guys,
i’m working on a late 2013 27’iMac and would like to increase performace with a dedicated drive for my AE Cache. I have a 1TB Fusion drive in my machine, so I was thinking on writing my cache to an external disc.
Does anybody have experience with the portable SSD “T3” from Samsung?
https://www.amazon.com/Samsung-T3-Portable-SSD-MU-PT500B/dp/B01AVF6UQQ/ref=sr_1_1?s=pc&ie=UTF8&qid=1482938215&sr=1-1&keywords=samsung+t3Or do you have other suggestions? I think it would definitely speed things up and its not that expensive, probably I would go for the 250 GB, maybe even 500GB and also use it for final rendering of projects.
I’m just a little confused about the overview table here: (scroll a little)
https://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E250B-AM/dp/B00OAJ412UUnder “Recommended For” it says here “Fast and Reliable External Storage” while for for the internal 850 EVO for example it says “Everyday Computing”. Is the T3 not suited for the constant writing/reading like the AE Cache would do? I already read from different sources that they use the T3 as boot disc, so actually i think it should work, but i did not find any posts on using the T3 as Cache for postproduction. Thats why im starting this thread now and hope for your help. ☺
Thanks in advance,
Simon
