Activity Forums VEGAS Pro External Recorders- ProRes
  • External Recorders- ProRes
    Posted by Gary Badgley on November 20, 2013 at 4:05 am
    I would like to deliver a short video to the local cable company, but my camera specs are not strong enough, and so I need to record to an external recorder to boost the bit rate and color space to meet the cable companies requirements.
    It seems that just about all of the recorders on the market are using ProRes, or the Avid codec. Nanoflash uses Mpeg 2 and produces the MXF files and this would be an easy choice, but the price is just beyond my means.
    So, I am trying to ascertain just how successful I would be in recording with the ProRes codec and editing with Sony Vegas. It seems after reviewing the past posts Vegas does not seem to be very successful working with these files. But I would like to hear some success stories using ProRes if there are any. Are there any success stories out there?
    Thanks, gary
    Stephen Mann replied 12 years, 10 months ago 6 Members · 10 Replies
  • 10 Replies
  • Kelly Griffin
    November 20, 2013 at 4:25 am
    Hey Gary–
    Not to evade your question, but why not just rent a camera that resolves your concerns?
    –Kelly
  • Stephen Mann
    November 20, 2013 at 5:44 am
    “… so I need to record to an external recorder to boost the bit rate and color space to meet the cable companies requirements.”
    This won’t change what the camera records. Just because HDV is 4:2:0 colorspace and ProRes and Avid DNxHD are 4:4:4, your video is still 4:2:0.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Gary Badgley
    November 20, 2013 at 12:41 pm
    Hi, thanks for the thought, but there are no rentals available where I live, besides I am shooting on the AF100 and with all my lenses etc, I would really like to shoot with my camera.
    Thanks.
  • Gary Badgley
    November 20, 2013 at 12:55 pm
    my camera records at 21 mbps. The color sampling is 4.2.0. I need a minimum 25 mbps and 4.2.2. As I understand it, when recording to an external recorder you bypass the cameras codec, in this case AVCHD AVC/H.264 and records using the recorders codec with a higher bit rate and improved color sampling. Am I misunderstanding this process?
  • Stephen Mann
    November 20, 2013 at 3:47 pm
    You never said what camera you have, but if it had an HDMI output port, then it is likely in 4:4:4 colorspace. You can use an HDMI recorder like the Atmos Ninja, but other than transcoding, I don’t know how to increase the bitrate. Also, note that ProRes is specific to FCP and you won’t find ProRes in the “Render As”templates. There is a tool that I have not tried that may help: FFmpeg customized for broadcast and professional usage
    Steve Mann
    http://www.mmdv.com
  • John Rofrano
    November 21, 2013 at 2:57 am
    [Gary Badgley] “my camera records at 21 mbps. The color sampling is 4.2.0. I need a minimum 25 mbps and 4.2.2.”
    My advice is to shoot with what you have, render to 25Mbps 4:2:2 and don’t worry about it. Cable companies will ask for the world, it doesn’t mean they are going to get it. I know of one broadcaster that demands 1920×1080 50 Mpbs 4:2:2. We shoot the show on a Sony Z1U HDV 1140×1080 25 Mbps at 4:2:0, render to 1920×1080 50 Mpbps 4:2:2 and the show is in it’s 4th season and the broadcaster has no complaints. Don’t get hung up over what you shoot. They just want to make sure you are not giving them inferior footage. Shoot as you normally do. I wouldn’t worry about it as long as your footage looks good.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Osbun
    November 21, 2013 at 2:42 pm
    Not all cameras pass uncompressed via HDMI out to an external recorder. For example, my Sony prosumer camera records 24mb/s to an internal SDHC card. If I hook up an external recorder via the HDMI output, i’ll still only get 24mb/s. My camera doesn’t offer clean HDMI out.
    Make sure your camera does offer clean HDMI out, because if it doesn’t you’re just wasting your time & money.
    Dave
  • Gary Badgley
    November 22, 2013 at 1:30 am
    Okay, the cable company does want it in 720 x 480 anamorphic 29.97 and they broadcast in SD.
    So, I imported and set up my project as NSTC DV(720×480 29.97? That letterboxed it, so I went down to the FX and matched output to aspect and that full framed it.
    Then when I tried to render it, I only got one choice it seems, and that is to render in NSTC DV and my .H264 gets wrapped in a .mxf file. Then I went to custom template and I could see where it gives me the 25 mbps, but I could not see where to get the 4.2.2 color sampling. How do I get 4.2.2.?
  • Scott Francis
    November 22, 2013 at 2:21 am
    I agree with John, shot as normal, deliver what they ask…they should not know the difference…
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Stephen Mann
    November 22, 2013 at 3:24 pm
    “they should not know the difference”
    Actually, the video is probably assigned to an intern who looks at the file properties and checks a box that it meets the specs.
    In the days of tape, your video has to be evaluated on a scope by a real video engineer.
    Steve Mann
    http://www.mmdv.com
