Activity Forums Blackmagic Design External Raid 0 FireWire HardDrive work with uncompressed capture?
  • Kristian Lam
    September 21, 2010 at 1:07 am
    Uncompressed 8-bit video (1080i0 requires about 120 MB/s of throughput. If you’re planning on using firewire 800 on the drive you’re referring to, it’s not going to be enough. If you use the eSATA connection on the QUAD model, then it should be ok.
    regards
    Kristian Lam
    Blackmagic Design
  • Danny Hays
    September 22, 2010 at 1:52 am
    Kristian Lam, What do you think of this drive for the shuttle capturing uncompressed? Danny Hays
    https://www.engadget.com/2010/09/15/lacie-ships-2big-usb-3-0-raid-drive-and-d2-usb-3-0-external-hdd/
  • Deledi Bingham
    October 6, 2010 at 10:36 am
    Thanks for the info Kristian.
    Do you happen to have a link to the graph that shows how much MB/s recording uncompressed footage the BMIP takes up?
    I know I had it somewhere but I can’t seem to find it.
    And just an opinion question, but how much improvement in video quality will I get recording uncompressed footage versus what I’m doing now recording with the MJPEG codec?
